1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
  3. Dear Pleskians, I really hope that you will share your opinion in this Special topic for chatter about Plesk in the Clouds. Thank you!
    Dismiss Notice
please help me with horde, with rebuild php
Discussion in 'Plesk for Linux - 8.x and Older' started by _Gohan_, Nov 28, 2007.
  1. _Gohan_
    _Gohan_ Guest
    my horde don't work, after rebuild php.- :confused:
    this is my ./conigure:
    './configure'
    '--build=i686-redhat-linux-gnu'
    '--host=i686-redhat-linux-gnu'
    '--target=i386-redhat-linux-gnu'
    '--program-prefix='
    '--prefix=/usr'
    '--exec-prefix=/usr'
    '--bindir=/usr/bin'
    '--sbindir=/usr/sbin'
    '--sysconfdir=/etc'
    '--datadir=/usr/share'
    '--includedir=/usr/include'
    '--libdir=/usr/lib'
    '--libexecdir=/usr/libexec'
    '--localstatedir=/var'
    '--sharedstatedir=/usr/com'
    '--mandir=/usr/share/man'
    '--infodir=/usr/share/info'
    '--cache-file=../config.cache'
    '--with-libdir=lib'
    '--with-sybase-ct=/usr/local/freetds'
    '--with-config-file-path=/etc'
    '--with-config-file-scan-dir=/etc/php.d'
    '--disable-debug'
    '--with-pic'
    '--disable-rpath'
    '--without-pear'
    '--with-bz2'
    '--with-curl'
    '--with-exec-dir=/usr/bin'
    '--with-freetype-dir=/usr'
    '--with-png-dir=/usr'
    '--enable-gd-native-ttf'
    '--without-gdbm'
    '--with-gettext'
    '--with-gmp'
    '--with-iconv'
    '--with-jpeg-dir=/usr'
    '--with-openssl'
    '--with-png'
    '--with-pspell'
    '--with-expat-dir=/usr'
    '--with-pcre-regex=/usr'
    '--with-zlib'
    '--with-layout=GNU'
    '--enable-exif'
    '--enable-ftp'
    '--enable-magic-quotes'
    '--enable-sockets'
    '--enable-sysvsem'
    '--enable-sysvshm'
    '--enable-sysvmsg'
    '--enable-track-vars'
    '--enable-trans-sid'
    '--enable-yp'
    '--enable-wddx'
    '--with-kerberos'
    '--enable-ucd-snmp-hack'
    '--with-unixODBC=shared,/usr'
    '--enable-memory-limit'
    '--enable-shmop'
    '--enable-calendar'
    '--enable-dbx'
    '--enable-dio' '--with-mime-magic=/usr/share/file/magic'
    '--with-sqlite'
    '--with-libxml-dir=/usr'
    '--with-xml'
    '--with-apxs2=/usr/sbin/apxs'
    '--with-mysql'
    '--with-gd'
    '--without-odbc'
    '--enable-dom'
    '--disable-dba'
    '--without-unixODBC'
    '--enable-pdo'
    '--enable-xmlreader'
    '--enable-xmlwriter'
    '--enable-mbstring'
    '--with-xsl=/usr'
    '--with-dom-xslt=/usr'
    '--with-dom-exslt=/usr/bin'
    '--enable-xslt'
    '--with-xslt-sablot'
    '--with-imap=/usr/lib'
    '--with-imap-ssl=/usr/include/openssl'
    '--with-mysqli'
    '--without-pdo-sqlite'
    '--with-pdo-mysql'
    '--with-mysqli=/usr/bin/mysql_config'
    '--enable-inline-optimization'
    '--enable-force-cgi-redirect' '--with-db4=/usr'
    '--with-ncurses'
    '--with-regex=system'
    '--with-xmlrpc=shared'
    '--enable-bcmath'
    '--with-mcrypt=shared'
    '--with-pear=/usr/share/pear'
    '--with-ldap=shared'
    '--with-mhash=shared'
    '--enable-mbregex'
    my test server is:
    http://www.sistemas-grumar.com/info.php
    webmail
    http://webmail.sistemas-grumar.com
    thank you for your help
  2. atomicturtle
    atomicturtle Golden Pleskian
    29
    Nov 20, 2002
    2,110
    7
    Washington, DC
    I have PHP 5.2.x packages available for CentOS/RHEL and Fedora in my archive. They are designed to work with Plesk environments.
  3. _Gohan_
    _Gohan_ Guest
    I try install atomic-test?
  4. atomicturtle
    29
    Nov 20, 2002
    2,110
    7
    Washington, DC
    Yeah thats got 5.2.5 in it, which is probably ready to go into the main channel, I just havent had the time to do it yet.
Loading...
