Plesk component does not work
T
Tuan AnhD
Please help me !
I have install Pleak Panel 10.4 on Window Server 2008 RC.But I can see that FTP and some component of Plesk does not work although I have Install fully Plesk's components.
When user login and and chose FTP Access management function,it open a new empty page.I dont know why ?
Please help me !
P/s :I'am come from VietNam,my english is not really good.
Could you please describe problem with more details? How it can be reproduced? What doesn't work exactly?
When I login to Plesk and go to FTP Access management function,It does not show anything.An empty page was show.I think the problem maybe come from intralling of Plesk
hi
I have the same problem, but more.
After the new update was installed
User Control Panel does not see the other pages and white pages can be seen
For example,Ftp Access ,dns ,file manager and other link in website & domain section on end user control panel Except a few links for example webhosting access
If they all worked before the update.
my plesk is 10.4.4
tank you
I think ,the problem maybe come from installing Plesk Panel.Some components was not installed corectly.Is anybody know how to reinstall components of Plesk Panel 10.4 ?
Please help me !
hi
After the new update was installed (10.4.4 Actualizar #32, última actualización May 26, 2012 03:42 AM)
they all worked fine before the update.
tank you
another one
I've got the same issue.
Microsoft Windows 6.1;build-7601;sp1.0;suite272;product3
This update has broken several things that previously where working perfectly.
- ftp access users admin
- backup administration page
- file browser management
- profile & preferences page (returns an empty error)
- branding theme
I have tried to install new branding theme 10.4, restart server and several things more. It's unaceptable to uninstall plesk and reinstall it because it is being used in a production server with almost a hundred domains. It seems that all server services are working but they are not administrable.
Please don't fall asleep to solve this big problem that is appearing in many servers.
Thanks for your quick answer Igor.
Windows event log seems to be ok but logs in plesk are a little messy.
On panel.log I got this:
2012-05-28T12:36:09+02:00 ERR (3): Failed to connect to sitebuilder - missing or incorrect C:\Program Files (x86)\Parallels\Plesk\/sb/include/init.php
but this error was appearing before.
and on php_error.log this:
[27-May-2012 07:00:00] Zend_Db_Statement_Exception: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '1-server.packages.synced' for key 1
file: C:\Program Files (x86)\Parallels\Plesk\admin\plib\Zend\Db\Statement\Pdo.php
line: 234
code: 23000
trace: #0 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Zend\Db\Statement.php(300): Zend_Db_Statement_Pdo->_execute(Array)
#1 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Zend\Db\Adapter\Abstract.php(479): Zend_Db_Statement->execute(Array)
#2 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Zend\Db\Adapter\Pdo\Abstract.php(238): Zend_Db_Adapter_Abstract->query('INSERT INTO `Se...', Array)
#3 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Zend\Db\Adapter\Abstract.php(575): Zend_Db_Adapter_Pdo_Abstract->query('INSERT INTO `Se...', Array)
#4 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Zend\Db\Table\Abstract.php(1075): Zend_Db_Adapter_Abstract->insert('ServiceNodeProp...', Array)
#5 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Db\Table\Dictionary.php(202): Zend_Db_Table_Abstract->insert(Array)
#6 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Service\Node\Properties.php(166): Db_Table_Dictionary->save()
#7 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Service\Node\Properties.php(150): Service_Node_Properties->_saveProperties()
#8 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Service\Node\Components.php(25): Service_Node_Properties->sync(NULL, false)
#9 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Service\Node\Properties.php(36): Service_Node_Components->sync()
#10 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Db\Table\Row\ServiceNode.php(179): Service_Node_Properties->__construct(Object(Db_Table_Row_ServiceNode))
#11 C:\Program Files (x86)\Parallels\Plesk\admin\plib\Db\Table\Row\ServiceNode.php(81): Db_Table_Row_ServiceNode->components()
#12 C:\Program Files (x86)\Parallels\Plesk\admin\plib\api-common\AbstractCu.php(1425): Db_Table_Row_ServiceNode->refreshProperties()
#13 C:\Program Files (x86)\Parallels\Plesk\admin\plib\cu\scheduled_backup.php(19): AbstractCu::componentUpdate()
#14 {main}
and this againg:
[28-May-2012 11:59:08] Failed to clear sitebuilder session: Failed to connect to sitebuilder - missing or incorrect C:\Program Files (x86)\Parallels\Plesk\/sb/include/init.php
but this errors appear before too.
I think it can be an error with the theme that didn't update propertly. I only find 10.4 themes but not 10.4.4 themes.
