• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Issue Plesk Daily Maintenance ReportUsage problem
s.kazimierczak
Debian 10.13
Plesk Obsidian 18.0.71 #2
I have/had a problem with DailyMaintenance, especially with ReportUsage. Every day it ended with failure exit code 255. This was in the logs:
PHP Fatal error: Declaration of PleskExt\DropboxBackup\Logger::log($level, $message, array $context = []) must be compatible with Psr\Log\AbstractLogger::log($level, Stringable|string $message, array $context = []): void in /opt/psa/admin/plib/modules/dropbox-backup/library/Logger.php on line 26
System updated, Dropbox backup extension - latest version.
So I have uninstalled the Dropbox Backup Extension and tried to run the ReportUsage manually and it eneded with error:
PHP Fatal error: Declaration of Psr\Log\NullLogger::log($level, $message, array $context = []) must be compatible with Psr\Log\AbstractLogger::log($level, Stringable|string $message, array $context = []): void in /usr/local/sb/vendor/psr/log/Psr/Log/NullLogger.php on line 26
[2025-08-07 10:56:58.581] 8636:68946a54d2643 ERR [panel] Class "Psr\Log\NullLogger" not found:
0: /opt/psa/admin/plib/modules/wp-toolkit/library/Service/Feature/FeatureManager.php:23
PleskExt\WpToolkit\Service\Feature\FeatureManager->__construct(object of type PleskExt\WpToolkit\Application\Plesk\PleskSettings)
1: /opt/psa/admin/plib/modules/wp-toolkit/library/ProjectServiceContainer.php:2592
PleskExt\WpToolkit\ProjectServiceContainer::getFeatureManagerService(object of type PleskExt\WpToolkit\ProjectServiceContainer)
2: /opt/psa/admin/plib/modules/wp-toolkit/library/ProjectServiceContainer.php:4949
PleskExt\WpToolkit\ProjectServiceContainer::getActionLogListenerProviderService(object of type PleskExt\WpToolkit\ProjectServiceContainer)
3: /opt/psa/admin/plib/modules/wp-toolkit/library/ProjectServiceContainer.php:3417
PleskExt\WpToolkit\ProjectServiceContainer::{closure:pleskExt\WpToolkit\ProjectServiceContainer::getEventDispatcherInterfaceService():3416}()
4: /opt/psa/admin/plib/modules/wp-toolkit/library/EventDispatcher.php:14
PleskExt\WpToolkit\EventDispatcher::getInstance(object of type WPToolkitDependenciesIsolationPrefix\Symfony\Component\DependencyInjection\Argument\RewindableGenerator)
5: /opt/psa/admin/plib/modules/wp-toolkit/library/ProjectServiceContainer.php:3416
PleskExt\WpToolkit\ProjectServiceContainer::getEventDispatcherInterfaceService(object of type PleskExt\WpToolkit\ProjectServiceContainer)
6: /opt/psa/admin/plib/modules/wp-toolkit/vendor/symfony/dependency-injection/Container.php:190
WPToolkitDependenciesIsolationPrefix\Symfony\Component\DependencyInjection\Container::make(object of type PleskExt\WpToolkit\ProjectServiceContainer, string 'Psr\EventDispatcher\EventDispatcherInterface', integer '1')
7: /opt/psa/admin/plib/modules/wp-toolkit/vendor/symfony/dependency-injection/Container.php:173
WPToolkitDependenciesIsolationPrefix\Symfony\Component\DependencyInjection\Container->get(string 'Psr\EventDispatcher\EventDispatcherInterface')
8: /opt/psa/admin/plib/modules/wp-toolkit/library/DI/Container.php:48
PleskExt\WpToolkit\DI\Container::get(string 'Psr\EventDispatcher\EventDispatcherInterface')
9: /opt/psa/admin/plib/modules/wp-toolkit/library/EventDispatcher.php:21
PleskExt\WpToolkit\EventDispatcher::dispatch(object of type PleskExt\WpToolkit\Application\Event\ApplicationShutdownEvent)
10: /opt/psa/admin/plib/modules/wp-toolkit/library/Application/BaseApplication.php:37
PleskExt\WpToolkit\Application\BaseApplication->shutdown()
11: /opt/psa/admin/plib/modules/wp-toolkit/library/Application/Plesk/PleskApplication.php:64
PleskExt\WpToolkit\Application\Plesk\PleskApplication->shutdown()
12: /opt/psa/admin/plib/modules/wp-toolkit/library/Application/BaseApplication.php:26
PleskExt\WpToolkit\Application\BaseApplication->{closure:pleskExt\WpToolkit\Application\BaseApplication::__construct():25}()
Now I installed again the dropbox backup extension, ran the ReportUsage manually again and it succeeded.
Now I believe it is fixed but what really was the issue and why they were wp-toolkit errors after I uninstalled Dropbox Backup.
