• Dear Pleskians! The Plesk Forum will be undergoing scheduled maintenance on Monday, 7th of July, at 9:00 AM UTC. The expected maintenance window is 2 hours.
    Thank you in advance for your patience and understanding on the matter.
plesk IIS (PHP?) problem
S
soncek1a
How can i reconfigure IIS with default values for PleskControlPanel? After instalation everything was ok, but later i had to change IIS and add .inc support.
Now when i start https://212.72.XXX.XXX:8443/ i get HTTP 500 - Internal server error.
My other domains (plainhtml) i defined before work ok.
I don't know what to do. Please help me=
hmm, i don't know where to start. It is no php problem. i made simple .html page in pleskControlPanel folder and it does not open from browser so iis doesn't serve it.
first i thought there was a problem in web folder configuration.
Later i wrote this in cmd:
C:\Program Files\SWsoft\Plesk\admin\bin>websrvmng.exe --reconfigure-all
Invalid pointer (COM Error 80004003) at getSiteAppPool(blog.123na.net, )
so is the reason that i deleted this blog folder manually?
Any other suggestion how to define problem more speciffic?
ok, i've restored this blog.123na.net folder from recycle bin :) I deleted SitesCache from registry and execute websrvmng.exe --reconfigure-all again and everything was ok. I was even able to made backup of existing projects.
From explorer i still get "The page can not be displayed". Hmm ...
Just for info:
-other webprojects (non SWSoft) on this IIS running ok,
-all plesk services are running. I've also tried to restart then
now i've removed friendly errors and in browser i've got:
The file index.php is part of Plesk distribution. It cannot be run outside of Plesk environment.
I thougt this might be connected with application pool in IIS, but it is on PleskControlPanel. Any other idea?
ok, Here i found solution:
http://kb.swsoft.com/article_144_1339_en.html
first i tried to delete licence key later i reconfigure from iis to php. So: It was PHP prob :) :)
But now there is more: Plesk does not recognize my licence number. I have that exe file with licence. I can not upload it, but when i click on retrieve licence i get:
License key PLSK.00403635.0000 is up-to-date
But after OK click there is plsk.00000000.0000 again
My valid licence no is PLSK.00403635.0000
