Issue Plesk Onyx Debian 8 problems
Was
Hi@All
I went into big problems on my Plesk 17.8.xx
I have removed the apt repo and now plesk does not start.
If i try the plesk repair, it says that the most packages are not found.
Can someone give me a Tip how can i solve my problem.?
if i try to reinstall it ends after some steps with that:
Code:
Aktion auswählen [F/b/q/s]: f
Pakete werden installiert
ERROR: Fehler bei der Deinstallation der Erweiterung "Plesk Migrator" (Paket: panel-migrator): PHP Warning: touch(): Unable to create file /var/log/plesk/panel.log because Permission denied; File: /opt/psa/admin/plib/Plesk/Log/Writer/File.php, Line: 9
External exception. "/var/log/plesk/panel.log" cannot be opened with mode "a"
Warnung! Es wurden nicht alle Pakete installiert.
Bitte prüfen Sie, ob Ihre Systemdienste betriebsbereit sind.
Bitte beheben Sie dieses Problem und versuchen Sie, die Pakete erneut zu installieren.
Wenn Sie das Problem nicht selbst beheben können, wenden Sie sich bitte an den technischen Support.
Deinstallation is not necessary, and moreover almost impossible. You just need to install Plesk over of those scraps left from previous installation.
Here is the next output:
Code:
**** Product perform-deferred-actions started.
===> Checking for previous installation ... found.
 Trying to register service xinetd... done
[2018-06-22 11:08:50.929] ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/apache-config' '-t'] with exit code [1]
[2018-06-22 11:08:54.463] ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/apache-config' '-t'] with exit code [1]
[2018-06-22 11:08:54.465] ERR [panel] Apache config (15296585270.57152300) generation failed: Template_Exception: (2)No such file or directory: AH02291: Cannot access directory '/var/log/apache2/' for main error log
(2)No such file or directory: AH02291: Cannot access directory '/var/log/apache2/' for error log of vhost defined at /etc/apache2/sites-enabled/000-default.conf:1
AH00014: Configuration check failed
file: /opt/psa/admin/plib/Template/Writer/Webserver/Abstract.php
line: 75
code: 0
Warning : failed to perform deferred action : httpd_reconfigure
 Trying to restart service apache2... Jun 22 11:08:55 atlas95.mydhp.de apache2[11509]: The apache2 configtest failed. ... (warning).
Jun 22 11:08:55 atlas95.mydhp.de apache2[11509]: Output of config test was:
Jun 22 11:08:55 atlas95.mydhp.de apache2[11509]: (2)No such file or directory: AH02291: Cannot access directory '/var/log/apache2/' for main error log
Jun 22 11:08:55 atlas95.mydhp.de apache2[11509]: (2)No such file or directory: AH02291: Cannot access directory '/var/log/apache2/' for error log of vhost defined at /etc/apache2/sites-enabled/000-default.conf:1
Jun 22 11:08:55 atlas95.mydhp.de apache2[11509]: AH00014: Configuration check failed
Jun 22 11:08:55 atlas95.mydhp.de apache2[11509]: Action 'configtest' failed.
Jun 22 11:08:55 atlas95.mydhp.de apache2[11509]: The Apache error log may have more information.
Jun 22 11:08:55 atlas95.mydhp.de systemd[1]: apache2.service: control process exited, code=exited status=1
Jun 22 11:08:55 atlas95.mydhp.de systemd[1]: Failed to start LSB: Apache2 web server.
Jun 22 11:08:55 atlas95.mydhp.de systemd[1]: Unit apache2.service entered failed state.
WARNING!
Some problems are found during restart service apache2(see log file: /var/log/plesk/install/plesk_17.8.11_installation.log)
have made. Now comes on plesk Panel Port:8443 that message
Code:
Warning: Unknown: failed to open stream: No such file or directory in Unknown on line 0
Fatal error: Unknown: Failed opening required 'auth.php' (include_path='.:') in Unknown on line 0
Try
# plesk installer --select-release-current --reinstall-patch --upgrade-installed-components
# plesk repair installation
on the first try of:
i get that response:
Code:
fork/exec /usr/local/psa/admin/sbin/autoinstaller: no such file or directory
On Second line (plesk repair installation) i get:
Code:
Unknown Plesk command-line utility: "repair"
