Originally posted by sammykona
Try doing it manually from the shell one domain at a time:
login to the plesk 7 server via shell and run :
password=your root pass on old server
and change your IP for the old server
PSA_PASSWORD=password /usr/local/psa/admin/bin/launchpad --deploy-agent --local-agent=/usr/local/psa/PMM/PleskX.pl --ip=222.22.22.22 --agent-name=PleskX.pl --login=root --agent-dir=/home/temp
PSA_PASSWORD=password /usr/local/psa/admin/bin/launchpad --dump-domains=domain.com --agent-status-file=/home/temp/PleskX.status --ip=222.22.22.22 --agent-name=PleskX.pl --login=root --agent-dir=/home/temp --dump-file=/home/temp/PleskX.xml
PSA_PASSWORD=password /usr/local/psa/admin/bin/launchpad --get-content --ip=222.22.22.22 --agent-name=PleskX.pl --login=root --agent-dir=/home/temp
PSA_PASSWORD=password /usr/local/psa/admin/bin/launchpad --remove-agent --ip=222.22.22.22 --agent-name=PleskX.pl --login=root --agent-dir=/home/temp
If all of the aboves goes ok, then login to migration manager on the new machine and select Import mode instead of Migration
hope this helps
