Problem installing Joomla
theywill
Basic Pleskian
Hi there,
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
CentOS 64 5.5, Plesk 10.2
PROBLEM DESCRIPTION AND STEPS TO REPRODUCE
Can't install Joombla through Plesk.
ACTUAL RESULT
Error: Unable to install the app because its installation requirements are not met. Contact your hosting provider to resolve this problem.
Requirements
PHP extension
The 'mysql' extension was not found.
PHP extension
The 'zlib' extension was not found.
PHP extension
The 'xml' extension was not found.
EXPECTED RESULT
All of these extensions are installed, and I have confirmed that with PHP info. Also, I have another instance of Joomla running on the same server (different domain).
I've tried switching from Apache module to FastCGI and changing some of the other settings, but of course, that had no effect.
ANY ADDITIONAL INFORMATION
Advice?
Thank you,
James
