W
webdrv07
Hello,
Having a problem using the latest migration utility, and I can't find what the issue is. Wonder if anyone can help
The agent is installed and running on the source server. (Winodws 2003 plesk 7 but has the same version PMM as the new plesk 7.6 server)
The manager is installed and running on the destination host. (Windows 2003 Enterprise Plesk 7.6)
The archives do get created on the source server and they do get downloaded to the PMM\source directory on the destination host, I see the .tgz files that have downloaded, they do not however get restored as accounts on the server.
The migration wizard appears to fully complete, no errors are displayed and I see the message migration completed. When I check, the migrated domain does not exist on the server at all, no IIS config, no files are restored.
This is the PMM log for the latest one I tried
----------------------------Exception_handled--------------------------------
psaobsolete.PSADatabaseQueryException: Syntax error in UPDATE statement.
at psaobsolete.PSAMySQLDatabase.execute(String queryStr)
at Restore76Exp.InplaceRestoreEngine.checkDomainAppPool()
at Restore76Exp.InplaceRestoreEngine.AddDomain(ObjectMigrationStage stage, domain param)
Debug 09/18/2006 23:21:04 : InplaceRestoreEngine.AddDomain domain.co.nz failed (returns false)
Debug 09/18/2006 23:21:04 : !!!! Rollback Transaction. !!!!
Debug 09/18/2006 23:21:04 : InplaceRestoreEngine::RollbackTransaction
Warning 09/18/2006 23:21:04 : Exception ignored: ( System.NullReferenceException: Object reference not set to an instance of an object. at Restore76Exp.RestoreStructure.ProcessDomain(Object obj, ReadStage stage) ) ( Object reference not set to an instance of an object. )
Debug 09/18/2006 23:21:04 : Domains successfully migrated to the client mydomains
It appears that there was an exception and this 'rolled back the transaction' thus the account does not exist on the server
Does this help with debugging ? I really need to get this to work today, as I have 200+ domains to add to a new server from a server running plesk 7.0 ..
Is it possible to restore the .tgz files somehow, manually from command line if the Plesk migrator is broken?
Many thanks for amy pointers, fixes or advice
