problem with contact forms
O
OscarO
Hi i have a problem with contact forms in my server, i don't use my server for mail service i have it disable, i have all domains configured with google apps. When someone send a contact form the server don't send it thinking it's form itself http://awesomescreenshot.com/0bf92on6f
In plesk 9 is disabled the mail option works well
What can i do? i tried to change dns options in domain but don't work, i only use server for hosting
Contact forms need sendmail to send out its emails ... sendmail is in /usr/sbin/sendmail. That will be there if you install any MTA like QMail or Postfix.
So, suggestion #1 is install any of the MTAs and if you dont want mail, go to settings, mail settings and close relay.
On the contrary, I have looked at your screen shot and I see a warning of Not Enough Disk Space. This could be the reason anyways...
Try creating more storage for your server too.
