Problem with fastcgi after update to 10.3.1
H
holgenoni
Hello to all,
after a plesk update to 10.3.1 I have a problem with fastcgi. The funny thing is that I get different errors on different webpages on the same server (with same configuration).
One Joomla site says "500 Internal Server Error", another says "Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 368640 bytes) in ...."
Another online shop application works fine without a failure.
After a check of the httpd/error_log I found the following error:
[error] mod_fcgid: process /var/www/cgi-bin/cgi_wrapper/cgi_wrapper(5440) exit(communication error), get unexpected signal 6
I can't find anything about that error. Does someone knows what to do? I am really a little bit frustraited that I have problems with plesk every time I upgrade.
Thank you very much in advice for any help
Best regards
