Problem with Firewall/Ftp
M
Megamec
I have a box with 1and 1 with Plesk 7.5. Now with the package, 1and1 include a 1&1 External Firewall (Cisco). The problem I have is each time I turn it ON, I cant access my server with ftp on all my account. If I turn if OFF, ftp is working fine. So what's the problem? If I have to configure it, what is the rule I have to put to make it work safely.
Thank's guys,
Mario ;)
I had the same problem also till I modified the external firewall rules. It doesn't have to be exactly like what I did below.
Go to the 1and1 Cisco Firewall module.
Edit the active rule set.
Add the following rule.
Remote IP: ALL
Protocol: TCP
Remote Port: Any
Local Port: Single Port = 21
Action: Allow
Status: Active
That is the rule I added and it works for me.
-Andrew
Remote IP: ALL
Protocol: TCP
Remote Port: Any
Action: Allow
Status: Active
-Andrew
Thank you, you fixed the problem :D
Now, I have another one. I transfered all my files on the server (inclued index.html) but I still have the original UNDER CONSTRUCTION PAGE. I dont know why, I have my own index.html file but the server still display the original one. Dont worry, I already flushed the cash on my browser ;-) Hope you have a good answer for me ;-)
There usually are several.
Was it something like the following?
/home/httpd/vhosts/default/httpdocs
-Andrew
There is a : /home/httpd/vhosts/default/htpdocs if I use the root access.
But I can see the domains name under : /home/httpd/vhosts
If I use ftp, I logged under the right domain so I transferted all my files under /httpdocs from ftp.
I don't know.
Try asking here.
http://www.1and1faq.com
-Andrew
Hey Andrew, can we chat under MSN, it's gone a be easier for me ;-) If you have a dedicated server with 1and1, your the right guys to help me configure my first domain un the server.
