    CentOS2Alma discussion
Problem with migration
J
JeramieA
Okay, I am very new to Plesk, but it is mostly user friendly, however I am having an issue with the migration from one server to the next. I tried to perform a migration on the 17th of may, it failed. The Plesk panel migration los does not display anything at all, however the logs on the server located in: /opt/psa/PMM/logs specifically the file pmmcli.log, displays this, at the end for today of course: (sorry ahead of time for the long post, but I know the more info the better)
</response>
6624: 2012-06-05 09:07:49,973 DEBUG --> <pmmcli.GetTasksListAction object at 0xa01050>
6624: 2012-06-05 09:07:49,973 INFO parameters: ['Migration']
6624: 2012-06-05 09:07:49,976 DEBUG <pmmcli.ActionRunner object at 0x9f3fd0>: doActivity
6624: 2012-06-05 09:07:49,977 DEBUG Acquired session mutex: MainThread
6624: 2012-06-05 09:07:49,979 INFO Executing <subprocess[6625] '/opt/psa/admin/bin/migration-handler --migration-get-task-status 20120531125408867'>
6624: 2012-06-05 09:07:52,089 INFO Execution of <subprocess[6625] '/opt/psa/admin/bin/migration-handler --migration-get-task-status 20120531125408867'> finished successfully.
6624: 2012-06-05 09:07:52,094 INFO Executing <subprocess[6628] '/opt/psa/admin/bin/migration-handler --migration-get-task-status 20120517085619765'>
6624: 2012-06-05 09:07:52,196 INFO Execution of <subprocess[6628] '/opt/psa/admin/bin/migration-handler --migration-get-task-status 20120517085619765'> finished successfully.
6624: 2012-06-05 09:07:52,197 DEBUG Released session mutex: MainThread
6624: 2012-06-05 09:07:52,222 INFO Executing <subprocess[6629] '/opt/psa/admin/bin/migration-handler --migration-get-task-status 20120531125408867'>
6624: 2012-06-05 09:07:53,696 INFO Execution of <subprocess[6629] '/opt/psa/admin/bin/migration-handler --migration-get-task-status 20120531125408867'> finished successfully.
6624: 2012-06-05 09:07:53,774 INFO Executing <subprocess[6631] '/opt/psa/admin/bin/migration-handler --migration-get-task-status 20120517085619765'>
6624: 2012-06-05 09:07:53,803 INFO Execution of <subprocess[6631] '/opt/psa/admin/bin/migration-handler --migration-get-task-status 20120517085619765'> finished successfully.
6624: 2012-06-05 09:07:53,804 DEBUG <pmmcli.GetTasksListAction object at 0xa01050>: response
6624: 2012-06-05 09:07:53,806 INFO Outgoing packet:
<?xml version="1.0" encoding="UTF-8"?>
<response>
<errcode>0</errcode>
<data>
<task-list>
<task task-id="1323" creation-date="2012-May-31 12:56:56">
<task-status task-id="1323">
<mixed>
<backup>
<working>
<dumping total-accounts="0" completed-domains="1" completed-accounts="0" total-domains="1">
</dumping>
</working>
</backup>
</mixed>
</task-status>
<additional-info>
<source-hostname>108.162.56.237</source-hostname>
<migrating-objects>
<selected-objects amount="1" type="domains">
</selected-objects>
</migrating-objects>
</additional-info>
</task>
Anyways, the log keeps repeating that, over and over and over again, it says successful, but when i check the destination servers migration temp folder, its empty. Is there a way to start the migration via command line, and in a way that it will be log info, be successful and keep the host/source from going offline when done? I have searched literally for hours for solutions to my problem, but to no avail, any help from the pros would be, JAWESOMELY and most appreciated. Thanks guys
I attached a picture of the panel, stuck at 50% since the 31st of may, 5 days later still truck, that seem normal? its only about 300GB to xfer. Thats what the server status is at from space from the plsxk manager panel, via internet explorer.
I am also using plesk panel version 9.5.2 with OS Linux 2.6.24-16-server.
Restarted the migration and now again its stuck at 50% after 7 days. What Is going wrong? The logs do not say anything has failed and it is just repeating that segment of info in the log hat I posted above.
-jeramie
From what I am reading in your post it looks like you are trying to initiate it from the source server and not from the new target server, is that right?
if so have you tried (or can you try) using the plesk migration manager and starting the migration from the new server instead via the GUI?
thanks
Hey thankyou for the reply and no I have not tried that but will. Now when I initiate it on the target server (new), is there anything that must be done from the source? IE: starting on the source as well so that they can get in sync? He, appreciate any help you can offer.
Again thankyou,
Jeramie
Jeramie, no there is nothing much to do at the source server. However, make sure the firewalls are open NOT to block migration agents from the destination.
