Problem with open_basedir
Andrew_Pa
Regular Pleskian
Hello to everybody!
I have problem with open_basedir value.
Every time I opened a new subscription I get :
" open_basedir restriction in effect. File .... is not within the allowed path(s): ({WEBSPACEROOT}/:{TMP}/) in Unknown on line 0, referer: .... "
Can you tell me what are the default values in php.ini ? Also If I put these values, my problem will fix?
Thank you very much for your time
Can someone chech the php.ini and inform me, what is the default value for the variable open_basedir ?
Thank you very much!
Please Can someone can check and tell me what is the default value for the variable open_basedir ?
I would appreciate that!
