Problem with PSA 7.5 autoinstaller and RPM
T
the_snatch
Hello,
I just tried to install PSA 7.5 on a clean Fedora Core 2 machine, after chmod +x the autoinstaller, I try to run it, and I get the following error:
./psa_installer_v2.0.0_build75050509.20_os_FedoraCore_2_i686: error while loading shared libraries: librpmio-4.3.so: cannot open shared object file: No such file or directory
Can anyone help? Do I have to reinstall RPM???
Is 'rpm' actually installed?
Try running:
rpm -q rpm
If it says 'command not found' or similar you don't have it installed.
I found the reason.... there's been a misunderstand: on the server was installed FC4 instead of FC2... :p
However I prefer the great autoinstaller: fast installation and no headaches with RPM & co :p
