Question Problem with SMTP connection
Importise
Hello,
I have a problem with the connection to the SMTP Server. On my computer I tried it with Outlook and Thunderbird, but it didn't work. I also tried it with my smartphone and it worked. On my smartphone I used Outlook. Why does Outlook work on my smartphone but not on my computer?
Does someone have an idea what the problem could be?
Here is my postfix config:
Code:
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific:  Specifying a file name will cause the first
# line of that file to be used as the name.  The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_tls_cert_file = /etc/postfix/postfix_default.pem
smtpd_tls_key_file = $smtpd_tls_cert_file
smtpd_use_tls = yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
# See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
# information on enabling SSL in the smtp client.
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
myhostname = hereismydomain.de
alias_maps = hash:/etc/aliases, hash:/var/spool/postfix/plesk/aliases
alias_database = hash:/etc/aliases
mydestination = localhost.hereismydomain.de, localhost, localhost.localdomain
relayhost =
mynetworks =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
virtual_mailbox_domains = $virtual_mailbox_maps, hash:/var/spool/postfix/plesk/virtual_domains
virtual_alias_maps = $virtual_maps, hash:/var/spool/postfix/plesk/virtual
virtual_mailbox_maps = , hash:/var/spool/postfix/plesk/vmailbox
transport_maps = , hash:/var/spool/postfix/plesk/transport
smtpd_tls_security_level = may
smtp_tls_security_level = may
smtp_use_tls = no
smtpd_timeout = 3600s
smtpd_proxy_timeout = 3600s
disable_vrfy_command = yes
smtpd_sender_restrictions = check_sender_access hash:/var/spool/postfix/plesk/blacklists, permit_sasl_authenticated
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated
smtp_send_xforward_command = yes
smtpd_authorized_xforward_hosts = 127.0.0.0/8 [::1]/128
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
virtual_mailbox_base = /var/qmail/mailnames
virtual_uid_maps = static:30
virtual_gid_maps = static:31
smtpd_milters = , inet:127.0.0.1:12768
sender_dependent_default_transport_maps = hash:/var/spool/postfix/plesk/sdd_transport_maps
virtual_transport = plesk_virtual
plesk_virtual_destination_recipient_limit = 1
mailman_destination_recipient_limit = 1
virtual_mailbox_limit = 0
smtpd_tls_ciphers = medium
smtpd_tls_mandatory_ciphers = medium
tls_medium_cipherlist = HIGH:!aNULL:!MD5
smtpd_tls_mandatory_protocols = TLSv1 TLSv1.1 TLSv1.2
smtpd_tls_protocols = TLSv1 TLSv1.1 TLSv1.2
message_size_limit = 10240000
I hope you can help me.
after I tried to log in I had this in my log file.
Code:
Dec 20 13:44:17 tr01 dovecot: imap-login: Login: user=<[email protected]>, method=DIGEST-MD5, rip=127.0.0.1, lip=127.0.0.1, mpid=13056, secured, session=<F1yKBe5DTKx/AAAB>
Dec 20 13:44:17 tr01 dovecot: service=imap, [email protected], ip=[127.0.0.1]. Logged out rcvd=90, sent=902
Dec 20 13:44:20 tr01 dovecot: imap-login: Aborted login (no auth attempts in 0 secs): user=<>, rip=87.XXX.XXX.XXX, lip=178.XXX.XXX.XXX, session=<x8uxBe5DgTVXh3Uj>
Dec 20 13:44:20 tr01 dovecot: imap-login: Aborted login (no auth attempts in 0 secs): user=<>, rip=87.XXX.XXX.XXX, lip=178.XXX.XXX.XXX, session=<r9+xBe5DgjVXh3Uj>
The log entries describe two different things. The first two lines show a login/logout via an IMAP webmail client, e.g. Horde, roundcube or another, individually installed client on the host. The second two lines describe a login attempt from an external client, maybe your Outlook. The error message in that is clearly shown with "no auth attempts", meaning that your client software did not attempt to transmit authentication data to login. This is most likely a problem of the Outlook client, a security software or a virus on your local PC that prohibits transmission of authentication data than a problem with the mail server on your host. Your host does not receive the login credentials. You will need to research the issue on your local PC, not on the host.
