    CentOS2Alma discussion
  • Please beaware of a breaking change in the REST API on the next Plesk release (18.0.62).
    Starting from Plesk Obsidian 18.0.62, requests to REST API containing the Content-Type header with a media-type directive other than “application/json” will result in the HTTP “415 Unsupported Media Type” client error response code. Read more here
Question Problems saving to partitions
Jmz
I have a problem and my english is not the best. I have 2 problems, the first has something to do with saving and it saves all websites to "/" and since I have only 50GB and 41GB are already occupied and under "/ home" are still 441GB (see photo Look Times this picture!). How can I reach all websites only under "/ home" stored, or should I reinstall Plesk 17 (Centos)?
And the second problem is that Plesk is always no longer reachable in the night, I have to restart the server every day, then click on IP under IP and "re-read", then comes an error is present, I repair it, Then the 3rd IP is again ping bar and must then restart the nginx service.
Thx
It looks like your partitions were not setup in a suitable way. Taking the nightly outage into account, it might be better to completely wipe the system and reinstall it from scratch. As all important default paths like /var/log and /var/www/vhosts are forking from / it might be a good idea to let / have the biggest share of disk space.
If you do not want to reinstall the OS and Plesk, you could move the virtual host path to a directory under your /home path. This KB article describes how to do that: How to change virtual hosts' location in Plesk for Linux . Some users have been reporting difficulties after applying that solution, so you might consider the other solution (reinstallation) if you are not experienced with permissions and Linux file hierarchy.
