Problems with @adminemail@
S
Simber
OS Microsoft Windows 6.1;build-7601;sp1.0;suite274;product3
Panel version 10.2.0
I have an issue where any forms created on websites sent via mail without an address defined are sent with a from address of @adminemail@.
Also the plesk panel default page is just showing this variable on the link.
I have checked the admin email address is entered & correct in the profile settings & any notifications sent from plesk are allow through the mail server & have the from correct address, I have checked the mail server to make sure that it is not the server creating this by sending reports internally from this.
The mail server is smartermail 7.6.
The websites & forms are being moved from a plesk 10.1 server & they work fine on that.
I think that’s all the information at present but any help would be great fully received
Cheers
Due to some strange problem placeholder located in %plesk_dir%\Additional\PleskPHP5\php.ini was not replaced. You can either replace it manually or try to launch:
"%plesk_dir%\ch_admin_email.exe" install [email protected]
This call should also replace placeholder on default server page.
Pavel almost correct but pointed me in the right direction cheers.....
I tried the ch_admin_email.exe but this had no effect this was located in C:\Program Files (x86)\Parallels\Plesk\admin\bin
I also tried to modify the php.ini in the pleskphp5 directory & restarted the server No Joy
I changed the varible in the php.in in the normal php directory
; For Win32 only.
;sendmail_from = [email protected]
sendmail_from = @adminemail@ *to adminstrators email address*
Restarted the server & now all appears ok.
Cheers for you help
This syntax is wrong. It's
"%plesk_bin%\ch_admin_email.exe" install [email protected]
And this doesn't change the "sendmail_from" directive in C:\Program Files\Parallels\Plesk\Additional\PleskPHP5\php.ini. Please explain how to affect the "sendmail_from" directive in plesk's default php.ini. Thank you.
