• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
qmail/horde problems
K
kburrell3
I recently had my server reimaged with fcore 2 with plesk 7.5. Since that time email has not worked. When trying to send a message through horde I get this error:
There was an error sending your message: unable to add recipient [[email protected]]: Invalid response code received from server
When I try to send an email to my self from another email address or from outlook I receive this error:
TEMP_FAILURE: SMTP Error (state 10): 451 qmail-spp failure: plugins/chkrcptto: can't execute (#4.3.0)
Any help to fix this would be appreciated. Feel free to ask for more info as I am not sure where to begin on this. I have scoured google for answers and came up with nothing. The onlything I have found so far that was close was in the FAQ's telling me to add 127.0.0.1/8 to my whitelist. It was already there I removed it, readded it and restarted the smtp and imap services to see if this would correct the error. As of now I have had no luck.
Just check do you have a qmail plugin chkrcptto:
$ ls -l /var/qmail/plugins/chkrcptto
-r-sr-xr-x 1 root root 14540 Jan 30 06:47 /var/qmail/plugins/chkrcptto
-r-sr-xr-x 1 root root 14532 Jan 27 23:28 /var/qmail/plugins/chkrcptto
yep it shows up.
Try this command:
ls -ld /var /var/qmail /var/qmail/plugins
drwxr-xr-x 24 root root 4096 Jul 4 2004 /var
drwxr-xr-x 10 root qmail 4096 Jan 30 06:47 /var/qmail
drwxr-xr-x 2 root qmail 4096 Feb 2 14:52 /var/qmail/plugins
Here ya go
drwxr-xr-x 23 root root 4096 Apr 25 06:58 /var
drwxr-xr-x 12 root qmail 127 Dec 10 11:30 /var/qmail
drwxr-xr-x 2 root qmail 22 Feb 17 04:44 /var/qmail/plugins
my file sizes are different thats all I see. Thanks for the help btw.
It is very strange, that the sizes of your directories differ from mine.
OK. Let's check the binary file "chkrcptto"
Create a fake domain in plesk, for example fakedomain.com
Then go to the mail preferences of this domain and set up the "Mail to nonexistent user" properties to the "Reject" value. Do not create any mailuser.
Then go to the command line and execute these commands:
# export [email protected]
# /var/qmail/plugins/chkrcptto
My output for the last command is:
E550 sorry, no mailbox here by that name. (#5.7.17)
I got the same output.
You might also want to check your /etc/hosts file ...
Does it say
Code:
127.0.0.1 localhost localhost.localdomain
Because Horde will need that .. it uses SMTP from localhost .. so localhost should resolve correctly. (<hordedir>/config/horde.conf)
I beleave, the problem is that qmail-smtpd cannot execute chkrcptto for some reason. We know, that chkrcptto works OK.
BTW, why your direcories /var/qmail & /var/qmail/plugins have so strange size? Are they symlinks?
Don't directories always show up with this size in an 'ls' command in Linux ?
I reimaged the server and email works now. However the folder sizes are still different. I was under the impression all folders should show 4096 who knows it works.
Broken
Hello Hello
This is the only place I could really see chkrptto mentioned.
Do you guys actually get output from it on stdout ?
Because if I do
So basically I get nothing out of the command... is it supposed to write to a file? Or is it just broken?
Thanks
-Ian
This fixed it.
I tried many things to fix it but only this helped:
rpm -qa |grep qmail
psa-qmail-1.03-fc4.build80060331.13
psa-qmail-rblsmtpd-0.70-fc4.build80060613.20
psa-qmail-1.03-fc4.build80060428.20
psa-qmail-1.03-fc4.build80060613.20
drweb-qmail-4.33-fc4.build80060613.20
rpm --erase --nodeps psa-qmail-1.03-fc4.build80060331.13 psa-qmail-1.03-fc4.build80060428.20 psa-qmail-1.03-fc4.build80060613.20
and then just install them again.
rpm -Uvh /root/psa/PSA_8.0.0/dist-rpm-FedoraCore-4-i386/base/psa-qmail-1.03-fc4.build80060331.13.i586.rpm /root/psa/PSA_8.0.0/dist-rpm-FedoraCore-4-i386/base/psa-qmail-1.03-fc4.build80060428.20.i586.rpm /root/psa/PSA_8.0.1/dist-rpm-FedoraCore-4-i386/base/psa-qmail-1.03-fc4.build80060613.20.i586.rpm
Maybe there will be other builds but you got the picture. :)
Hope this will help so.
