    CentOS2Alma discussion
Removing system skins - is it possible
M
m.r.davies
Hi
I would like to remove a few of the site builder skins/interfaces and only display a few of them
...basically i want to remove all the plesk themes/skins
Is this possible? is it driven by an xml file or anything?
When i say skins i mean admin areas and not templates.
cheers
Hello,
There is no standard way to disable Sitebuilder skin. Why do you need it? We'll try to figure out your problem and add feature request for the next versions.
Hi
I want to limit the amount of skins available as i dont like them all.
It might be easier to just turn this option off for all users??
That makes sense, we'll plan this feature for next releases.
