    https://survey.webpros.com/
Issue 'run-parts: /etc/cron.daily/60sa-update' in my mailbox today?
jmar83
Regular Pleskian
Why?
Screenshot here:
What is "sa" from "60sa-update" ?
Thank you very much for your feedback.
Hi
Thank you for your feedback.
1.) I don't have that mail daily
2.) It has an exit code that not equals 0 which implies an error or at least a warning (which must not imply a problem in every case)
3.) The file /var/log/sa-update.log seems to be huge, but on the last line i see:
You can disable the sa-update execution by moving 60sa-update file from /etc/cron.daily to a different location:
# mv /etc/cron.daily/60sa-update /root
This is an OS notification. If you don't want it either move the /etc/cron.daily/60sa-update as Igor said or add an empty MAILTO="" in the script (this can be overwritten by an upcoming Plesk update):
Code:
#!/bin/bash
MAILTO=""
### Copyright 1999-2022. Plesk International GmbH. All rights reserved.
sa_update()
@maartenv : Thank you very much.
@IgorG : Regarding your link to the other thread with PERL source code: What do you think about that hotfix solution?
Perl:
sub read_content {
  my ($file_name, $binary_mode) = @_;
  my $content;
  my $file = IO::File->new;
  # Custom {
  if (-e $file_name) {
    #print "File $file_name exists!\n";
    # Original source code {
    $file->open($file_name, '<') or die "Cannot open file $file_name: $!";
  if ($binary_mode) {
    binmode $file;
  my($number_of_bytes,$buffer);
  $content = '';
  while (($number_of_bytes = $file->read($buffer, 16384)) > 0) {
    $content .= $buffer;
  defined $number_of_bytes or die "Error reading from file $file_name: $!";
  $file->close or die "Error closing $file_name: $!";
    # } Original source code
  else {
    #print "File $file_name does not exist!\n";
    my $logfile = '/var/log/sa-update-userlog.log';
    my $str = "File $file_name does not exist!";
    open(FH, '>', $logfile);
    print FH $str;
    close(FH);
  # } Custom
  return $content;
if (-e $file_name) ... else ... is MY code and the code in "if" condition is still the same as original :)
