Issue run-parts: /etc/cron.daily/pleskupdate exited with return code 1
@mxk thx a lot, where exactly do i find that script?
still does not seem that strato will fix that problem anymore so u would help a lot of us i believe :)
It is the mentioned
After a few weeks now, I have not received any further mail with a fail.
Thank you so much.
After a couple of weeks i can say, that it works 75% if the time. So i switched to a sleep of 240 and i think it works.*
thanks again for the fix
I had the same issue with a root server from Strato. For analysis I have executed the script /etc/cron.daily/pleskupdate directly. Most time the response code was 0, so there was not a directly problem with it. But when I have used run-parts --report /etc/cron.daily, what is used by the server to start automatically all scripts in this directory, I have received the annoying mail with the info "run-parts: /etc/cron.daily/pleskupdate exited with return code 1". A directly start of /etc/cron.daily/pleskupdate afterwards have then also finished with return code 1.
I have noticed the message "Update operation was locked by another update process." in the autoinstaller3.log. Maybe there are some other scripts in /etc/cron.daily, that are blocking something for a short time?!
So I have added a simple sleep to the pleskupdate script, what at first glance solved the issue on my server.
This is the current script:
Bash:
#!/bin/sh
# Plesk autoinstaller
sleep 120
/usr/local/psa/admin/sbin/autoinstaller --select-product-id plesk --select-release-current --install-component base >/dev/null 2>&1
Exactly, I think that it was just lock collision too...
I checked first with this code
sudo run-parts --report /etc/cron.daily
sudo tail -n 100 /var/log/plesk/install/autoinstaller3.log | grep -i lock -n
It tells
100:[2025-09-04 13:50:41.462797] Update operation was locked by another update process.
Then i backed the script up:
sudo cp /etc/cron.daily/pleskupdate /etc/cron.daily/pleskupdate.bak
An then used this script:
sudo bash -c 'cat >/etc/cron.daily/pleskupdate <<EOF
#!/bin/sh
LOG=/var/log/plesk/cron-pleskupdate.log
LOCK=/run/lock/pleskupdate.lock
# random jitter (0–299s) so we don’t collide with other daily jobs
sleep "\$(awk '\''BEGIN{srand(); print int(rand()*300)}'\'')"
# run only if we can acquire the lock; if locked, exit 0 to avoid spammy mails
if command -v flock >/dev/null 2>&1; then
/usr/bin/flock -n "\$LOCK" -c "/usr/local/psa/admin/sbin/autoinstaller \
--select-product-id plesk \
--select-release-current \
--install-component base >>\"\$LOG\" 2>&1" || exit 0
else
sleep 240
--install-component base >>\"\$LOG\" 2>&1 || exit 0
fi
exit 0
EOF'
sudo chmod 755 /etc/cron.daily/pleskupdate
Not sure if my script is totally fine bu so far no problem... I don't receive those fail mails anymore...
