run-parts: /etc/cron.daily/pleskupdate exited with return code 1
Liwindo
Basic Pleskian
Username:
TITLE
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
Plesk Obsidian 18.0.58, Ubuntu 20.04.6 LTS, x86_64
PROBLEM DESCRIPTION
Summary:
After upgrading to 18.0.58 daily an error mail for the plesk update arrives with the content
Code:
Cron <<user>@<hostname>> test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
I can verify that for the two Server instances I have.
It was observed that plesk still updates the minor patch versions correctly while still sending this mail. Also after switching to the official plesk repository it didn't stopped.
The workaround provided by Issue - run-parts: /etc/cron.daily/pleskupdate exited with return code 1 hasn't worked, now the following content is received:
Code:
/etc/cron.daily/pleskupdate:
ATTENTION: The command line option &quot;--reinstall-patch&quot; is obsolete and will be ignored.
ERROR: Error when analysing the command line: No arguments are allowed after the options.
The following arguments were found after the last option:
/dev/null
STEPS TO REPRODUCE
Not known
ACTUAL RESULT
error mails with content mentioned above
EXPECTED RESULT
no error mail
ANY ADDITIONAL INFORMATION
Please provide at least a workaround on short notice which supresses the mail, as it's higly annoying.
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM
Confirm bug
It's a known issue. Plesk is in touch with Strato to clarify this problem:
@CHE Did you check the thread that Maarten provided? You should be able to remove the one line from the cron job that doesn't belong there.
remove
/opt/psa/admin/sbin/autoinstaller --select-product-id plesk --select-release-current --reinstall-patch --install-component base 2>&1 /dev/null
from
remove
from
I have not try it yet. I have comment that line out now. We will see it tomorrow, if it fix it. Thank you very much!
Plesk cannot find a solution as the line is introduced by Strato. We cannot just remove it, because there could be cases where such a line makes sense.
