Setting up a service and monitoring it is always running
PingmeDiego
Hi, I have Plesk Panel 11, and had 2 related questions:
1. I have a script that I need to run in the background, and that it should always be running with the command below:
nohup sh /var/www/path-to-script/script.sh > /tmp/script.log & 1>&2
the script basically goes into a while loop where it is running some tasks, sleeps for a second, and then does it again.
Is there a way to setup this up as a service in plesk? And is there a way to monitor that it always runs?
2. Does plesk have the ability to monitor logs for specific keywords? In the log to the script above, I would want to get alerted whenever the word 'error' appears, for example.
Thank you!
Diego
