Several Technical Difficulties I would like help with...
L
LexisSims2
Hello, I currently have Sitebuilder 4.0 from Host Gator. So here are a few problems I am having trouble with, and it would be nice if I could have some help.
1. I would like to upgrade from 4.0 to 4.5. I really don't know how to, I read the guide.
2. I would like to get new Modules (Host Gator currently only supports the Script. I don't even know what that does.)
3. I was also wondering if there is anyway that I can put videos onto my site (like from YouTube perhaps.)
4. One more thing... I would like to know how to add a second navigation bar on the sides like I see in the preview of the templates.
If I can get any help with these, thank you very much.
NOTE: For the Modules I went under all the download links to find them, but, I am having major problems getting them onto the Sitebuilder.
Also, I would like to know if there is a certain folder that I need to put these in after I have downloaded them.
Please, and thank you!!
1. Sitebuilder upgrade requires root access to the server where it's installed. If you have it, you can accomplish installation according to installation guide: http://download1.parallels.com/SiteBuilder/4.5.0/doc/install/en_US/html/index.htm
The easiest way to do this is to use Sitebuilder autoinstaller. But remember you need to have remote root server access. Contact with Hostgator concerning this case
2. There was similar discussion related to missing modules on Hostgator sites for Sitebuilder. Please check the following link: http://forum.swsoft.com/showthread.php?t=53934&highlight=Hostgator
Modules can be installed only on the server itself and there is no way to do this through GUI.
3. You can put your Youtube video using Script module. Just add Script module into Sitebuilder and add youtube link into it. For more information about how to work with Script module you better refer to Sitebuilder manuals:
http://www.parallels.com/en/sitebuilder/docs
4. Preview shows only example and second navigation bar will appear only for special pages like E-shop or Image gallery.
Thank you very much. I will check these out. Thanks again!
