    CentOS2Alma discussion
SiteBuilder 4.5 Installation Error, please help.
P
PremF
Hello,
I have installed SiteBuilder 4.5 by an Autoinstaller downloaded from http://www.parallels.com/download/sitebuilder4/#CENTOS5X86_64.
Packages were installed with this error:
[FATAL] No suitable PHP found
There were some configuration errors, check logs
The packages were installed successfully.
Here is my php detail:
# php -v
PHP 5.2.11 (cli) (built: Sep 21 2009 14:52:42)
Copyright (c) 1997-2009 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2009 Zend Technologies
with the ionCube PHP Loader v3.3.7, Copyright (c) 2002-2009, by ionCube Ltd.
I have tried to redefine php path by using:
# sb_config --phpcli_path /opt/php52/bin/php5 --phpcgi_path /opt/php52/cgi-bin/php5
(from the suggestion in this topic: http://forum.parallels.com/showthread.php?t=81523)
But it also showed the same error as before:
Logs saved to /usr/local/sitebuilder/tmp/sb_config-1001051638.log
When I tried to set admin user/password via Sitebuilder Setting in Plesk.
There's an error:
Error: Unable to retrieve the information from the Sitebuilder system:
SOAP-ERROR: Parsing WSDL: Couldn't load from 'http://sitebuilder.webnity.com/ServiceFacade/SystemWebService.asmx?WSDL'
Please suggest.
As possible reason problem can be caused by inconsistency of package php5-ioncube-php52, for example. Try to check it with something like:
rpm -V php5-ioncube-php52-4.5.0-centos5x86_64.08052912
(note that you can have other name of installed php5-ioncube-php52 package - use correct there). Also chec content of /usr/local/sitebuilder/tmp/sb_config-1001051638.log log file. Most probably you will find something useful there.
