G
geehun
i have created new domain template which is enable log rotation.while i were using it, i have created domain accounts my 7.6.1 Plesk panel. but after these operations, now i cannot any operation on domain
accounts wihch i have created with enable log rotation. i cannot remove created domains, i cannot change domain status(activate or deactivate), i cannot take any backup.
Please help me immediately. what can i do?
i cannot remove domain.
Error: Unable to remove domains: Problems occured while removing domains: Unable to turn the domain OFF: domainmng failed: Execute logrot_mng "addeskisehir.com" off by_time daily false failed: Missing
required parameter compress. Possible parameters is:
config_fname
status
type
parameter
max_number_of_logfiles
compress
Error: Unable to activate/deactivate domain: domainmng failed: Execute logrot_mng "addeskisehir.com"off by_time daily false failed: Missing required parameter compress. Possible parameters is:
config_fname
status
type
parameter
compress
[email].
Error: Unable to create the backup file: Error domain_bu execution: Backup process has failed for domain 'addeskisehir.com'
Error in execute ''domainmng' --turn-off "--domain-name=addeskisehir.com"':Execute logrot_mng "addeskisehir.com" off by_time daily false failed: Missing required parameter
config_fname
status
type
parameter
compress
[email].
config_fname
status
type
parameter
compress
config_fname
status
type
parameter
compress
[email].
config_fname
status
type
parameter
compress
[email].
