    CentOS2Alma discussion
[Solved] Webdav does not work on Ubunt 14.04 LTS@Plesk 12.5
networkinghomer
we have an Ubuntu 14.04 LTS vServer running on Plesk 12.5. The problem is, that webdav-login fails with 401-error. Apache-modules are enabled (dav*). Ist also does not work using localhost.
Any ideas? Is it a bug? Can anyone confirm webdav is running with plesk 12.5@ubuntu?
Cheers,
Homer
yes, WebDAV on Ubuntu 14 and Plesk 12 is working fine.
Are you running Mod Security?
And have you tried...
Code:
# /opt/psa/admin/sbin/file-sharing --sync
Regards
Lloyd
Solved!
The trick was to ad this 3 lines
RewriteEngine On
RewriteCond %{HTTP_HOST} domain.tld
RewriteRule ^(.*)$ - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
In both sections (https+http) of apache-settings in plesk.
