Solving at Once those permission problems ...
How do you find the permission issue in Plesk11 ?
  • Annoying, not enough documentation about it
    Votes: 0 0.0%
  • Did not affected me
    Votes: 0 0.0%
  • Don't Now
    Votes: 0 0.0%
  • Total voters
    1
AlexIMS
Up to the release of Plesk 10.4, in versions 9 respectively 10-10.3 you could use vhostmng to reset the permissions on domains.
http://kb.parallels.com/en/6572 - this explains more about it.
Now, have documentation that vhostmng support has stopped since 10.4 realy made me nt to even consider upgrading my plesk version.. which I actually needed to do yesterday due to a problem that appear in the auto-installer for Wordpress ( remember that this is the same day Wordpress 3.5 was released)
Now the only you can actually found to reset the permissions is this-one:
http://forum.parallels.com/showthread.php?t=264710 - carefull when you use it as will reset all the file permission outside httpdocs and if have subdomain like me outside the httpdocs folder you will have loads of fun.
No office to the Plesk team, but this it's absolutely ridiculous and already fell like I might spend the time between Christmas and New Year on Moving My server onto Cpanel and WHM. There's more than 2 years since we encounter this problem and there is not a proper post of how to deal with this problem.
Why not include mod_suphp or mod_ruid2 as a add-on apache module or something? And even that, does it work, I have tried with Plesk 11 and does not pull the trigger, maybe I did something wrong or anything but still the fact that we don't have a solution form sorting out this problem with the permission after 2 years and there's not much done about it shows nothing else that disrespect from your management and development team guy's.
Please let me know if anybody from your team consider sorting this out once forever as I am tired with resetting permission at least a couple of times every single week.
I do Consider however that your application has been constantly improved in past 2 year, but you should address the permission issue on a URGENT matter.
The script looks good, wish found it earlier..
Hi Igor, thank for your quick reply, the script looks good and very helpful, I wish I found it earlier. Will try it out as soon as get a as would like to backup all before just in case.
Will let post here if it worked or not.
