E
elgordo
I would like to do the following:
change my server configuration to have my httpdocs folder be a symlink to the httpsdocs folder.
I have been given the following advice but I have no idea how to go about it.
In your server's domain configuration (at the admin level, perhaps not at the general user level) you should be able to do this via a checkbox. If not, then perhaps you can create the symlink yourself via the command line. If you need help, talk to the server administrator.
Can this be done in the Plesk control panel or am I looking in the wrong place.
Thanks,
Gordon.
Thanks,
Gordon.
