Summary of current problems
Thomas Wilhelmi
Regular Pleskian
So, I would like to summarize my current issues with my Plesk Panel. I have openSuse 12.3 and Plesk 11.5.30. Both with latest patch-level.
- since a couple of days I receive mails that over night the automatic updater updated my Panel. I didn't changed any configuration.
- since than my Administrator-Language is changed automaticaly evary morning to English. The standard-language is German.
- Watchdog generates it'S reports only weekly even it is configured to do this daily
- Samba is shown as inactive even if it's active
- VPN must be restarted daily to get a Connection
- rkhunter-config is overwritten by Plesk-updates.
Is there any Chance to get some of this issues fixed in the near future?
Just installed MU#13 wich was installed like a complete new product. No changes in the mentioned Points. Languages changed again to English and all other Points still true. And I forgot to mention that the Service-Watchdog is disabeld after such an update. This happened again.
Have you tried to disable automatic update in Update and Upgrade Settings at least?
I just restartet my Server to get a clean Startup and other Problems came up again. So after reboot the Firewall still have Problems:
h1431219:/home/willi # systemctl status psa-firewall.service
psa-firewall.service - LSB: Plesk firewall
Loaded: loaded (/etc/init.d/psa-firewall)
Active: failed (Result: exit-code) since Fri, 2013-08-23 23:41:19 CEST
Process: 1515 ExecStart=/etc/init.d/psa-firewall start (code=exited, status=1/FAILURE)
CGroup: name=systemd:/system/psa-firewall.service
Aug 23 23:41:19 h1431219 systemd[1]: Starting LSB: Plesk firewall...
Aug 23 23:41:19 h1431219 psa-firewall[1515]: psa-firewall: service is disabled
Aug 23 23:41:19 h1431219 systemd[1]: Failed to start LSB: Plesk firewall.
Aug 23 23:41:19 h1431219 systemd[1]: Unit psa-firewall.service entered failed state
with exactly NO rule defined.
SMB Directly after reboot:
h1431219:/home/willi # systemctl status smb.service
smb.service - LSB: Samba SMB/CIFS file and print server
Loaded: loaded (/etc/init.d/smb)
Active: inactive (dead)
CGroup: name=systemd:/system/smb.service
after activating in the Panel:
Active: active (running) since Fri, 2013-08-23 21:48:14 CEST; 58s ago
Process: 3227 ExecStart=/etc/init.d/smb start (code=exited, status=0/SUCCESS)
â 3238 /usr/sbin/smbd -D -s /etc/samba/smb.conf
â 3253 /usr/sbin/smbd -D -s /etc/samba/smb.conf
Aug 23 21:48:13 h1431219 systemd[1]: Starting LSB: Samba SMB/CIFS file and print server...
Aug 23 21:48:14 h1431219 smbd[3237]: [2013/08/23 21:48:14.340379, 0] param/loadparm.c:7896(lp_set_enum_parm)
Aug 23 21:48:14 h1431219 smbd[3237]: WARNING: Ignoring invalid value 'none' for parameter 'printing'
Aug 23 21:48:14 h1431219 smb[3227]: Starting Samba SMB daemon ..done
Aug 23 21:48:14 h1431219 systemd[1]: Started LSB: Samba SMB/CIFS file and print server.
with the following showing in the Panel:
notice the language I originally configured to German!
And since the update from yesterday drweb does not update Automatically.
Sorry for being poking but this is really getting terribly annoying.
