Question sw-engine fix for CVE-2026-109618/109619 on Plesk 18.0.72 (Ubuntu 18.04)?
simmons
Ubuntu 18.04.6 LTS
Plesk Obsidian 18.0.72 Update 3
Hi, thanks for the quick fixes for the PHP handlers.
Question about sw-engine on older installs: my server runs Plesk Obsidian 18.0.72.3 on Ubuntu 18.04
(the latest version the installer offers for this OS). The PHP handlers (8.2.35, 8.3.36, 8.4.27 and
the 7.4 build of 21 Oct) installed fine, but sw-engine remains unpatched.
Is a sw-engine hotfix planned for 18.0.72 / Ubuntu 18.04, or is the dist-upgrade to a supported OS
the only way to get the panel fixed? In the meantime, is setting session.upload_progress.enabled = 0
in sw-engine's php.ini a reasonable interim mitigation?
Thanks!
Do you have the "The Extended Lifecycle Support (ELS)" and is the TuxCare ELS extension active?
Log in to Plesk using your administrator credentials. Then go to [B]Tools & Settings[/B] > [B]License Information[/B], and check the status of the TuxCare service license.
see: Plesk Version Lifecycle Policy
Ubuntu 18.04
Plesk continues to deliver the new Plesk Obsidian version with the usual schedule including new features, and functional and security updates if it doesn’t contradict the Software delivered by the OS vendor until the Duration of Extended Lifecycle Support: October 1, 2024 – January 1, 2028.
