Upgrade 10.0.1 to 10.1.0 and/or 10.1.1 with problems
xxx
Basic Pleskian
Hello, together.
I have done an upgrade from my plesk panel 10.0.1 to 10.1.0 and 10.1.1. Witrh both Upgrades I get some problems.
I do not use the update function of the webinterface. Instead I'm using autoinstaller.
From 10.0.1 to 10.1.0 I get the message:
ERROR: Unable to install the "psa-drweb-configurator-10.10.0-suse11.1.build1010101227.14.i586" package.
Not all packages were installed.
Please, contact product technical support.
After the I could'nt login at Plesk. At login scren and using user admin I get the messages
ERROR: PleskMainDBException
Table 'psa.lockout' doesn't exist
After the I try to update from 10.0.1 to 10.1.1 also with the utoinstaller and I get the messages
===> Upgrading database
Trying to start service mysql... done
Trying to establish test connection... connected
done
Trying to find psa database... version is 010100
DATABASE ERROR!!!
Previous product version is 10.9.0, but previous database
version is 010100. In most of cases it is result of
previous upgrade try failure. Please, restore previous version
from backup, and try again or contact technical support.
ERROR while trying to check database version
Check the error reason(see log file: /tmp/pp10.10.1-bootstrapper.110407.12.49.log), fix and try again
**** Product prep-install failed.
***** problem report *****
ERROR: An error occurred during performing of installation PREP actions (see log for details). Installation was rolled back.
Warning! Not all packages were installed.
Please check if your system services are operable.
Please resolve this issue and try installing the packages again.
If you cannot resolve the issue on your own, contact product technical support for assistance.
Plesk isn't running anylonger.
So, I don't know what to to to upgrade without errors.
Could someone help me or it is better to wait for the next major release?
Thanks a lot for all!
