    CentOS2Alma discussion
Username authentication problem after upgrade
I
ignus
It seems that with 8.1 all usernames are case sensitive in all email related authentication. I've tested POP, IMAP, SMTP AUTH and webmail.
I'm pretty sure it wasn't doing that before.
Anyone have any idea on how to switch that back to case INsensitive?
Thanks
I got plesk 8.0.1 and usernames ARE case sensitive.
Anyways... email addresses should always be lowercase :p
I understand the username part, but not the domain part. Ie, before 8.1 if the domain was put in as JoeBob.com you could log in using joebob.com. It's not a huge deal, just a little annoying..
Thanks
Oh, look closer to Server > Mail > Names for POP3/IMAP mail accounts property
Sorry, I wasn't very clear. I saw the option in the Server -> Mail area, but that's not the issue I'm talking about.
before a client could log with with any of these as the username:
[email protected]
[email protected]
[email protected]
etc
Now it HAS to match the case of the domain in the system.
ie, if the domain is JoeBob.com in Plesk, they HAVE to log in as [email protected] or it will not work.
I could understand the usernames being case-sensitive, but domains shouldn't be as joebob.com and JoeBob.com is the same domain name.
Thanks
Not yet
Hi There
Nope, not fixed yet, still waiting
Any suggestions would be greatly appreaciated
Wayne
Anyone find a fix for this? Took two servers to 8.1 last night and no one can send now.
Update: Sorry, I posted on the wrong thread, for me authentication is failing for smtp after the upgrade, usernames have always been case sensitive as far as I know.
I just upgraded to 8.1.0 and testing this and did not see the problem. They must have fixed it in the hotfix.
Dean
Problem fixed
Hi Guys
Once SW-Soft support team tackled the problem they solved it quite quickly, I'm not sure if they have fixed the issue in a hotfix or not.
I know the next 3 servers I do will be with a bit more research before hand.
Thank you support for the help in fixing the issue
Regards
Wayne
