    CentOS2Alma discussion
Issue Using Let's Encrypt Certificate For Parallel Power Panel https:// .... :4643
ArshadM
By choosing Let's Encrypt Certificate through Tools & Settings\SSL/TLS Settings in the Plesk Control Panel, the certificate is working fine for the https://.........com:8443 & for all domains hosted in the control panel . However, for Parallel Power Panel https://.........com:4643 it is still using the default invalid and expired certificate as originally installed.
https://.........com:4643 sites shows not a secure web site.
How to also use the Let's Encrypt Certificate also for https://.........com:4643 ?????
Regards.
Hi Arshad,
this certificate is not manageable from within a CT/VPS.
The certificate is from VZPP and has to be replaced manually by the admin of the node.
Regards
Kristian
it should be /etc/httpd/conf/ssl.crt/server.crt on the Virtuozzo node.
But you can look at /etc/opt/pva/pp/plugins/httpd/include.ssl.conf for the exact location.
Regards
Kristian
