Backups problem plesk 10.44
BenFran
I am having problems with plesk panel 10.4.4, I have scheduled automatic backups and it runs ok, but it does not save the files in httpdocs. The database and mail get backed up ok, but not the website files.
I have the following backup configuration:
-Save backup in repository
-Save all content and configuration.
These are the files and folders in the zip file generated:
.discovered
databases
phosting
mybackup_domain.com_mn_121212.tgz
mybackup_domain.com_vhost_121212.tgz
mybackup_domain.com_info_121212.xml
Any ideas?
In phosting
.discovered
databases
phosting
Any ideas?
in phosting folder you can extract _vhost folder with gz.zip via winrar and then you can see httpdocs contents.
