Resolved Binding Plesk to a specific IP and port combination does not work in Plesk 11.5?
King555
Silver Pleskian
In version 11 I configured my Plesk in that way that the Panel was only reachable under one specific IP (I have several on the server) and on one specific port.
For the port(s) I edited /etc/sw-cp-server/applications.d/plesk.conf and for the IP /etc/sw-cp-server/applications.d/plesk.socket.sh.
But Plesk 11.5 is now reachable on every IP and on the default port. Why? Of course I checked my edited files after updating.
Plesk control panel uses new engine in 11.5, therefore your changes are useless now (if not harmful). You need to adapt them to archive the same behavior.
Thanks. I will undo the changes and search for the new files.
EDIT: Found it! It's much simpler than before.
Just edit ipv6_ports.inc and plesk.conf in the directory /etc/sw-cp-server/conf.d
Change e.g. "listen 8443 ssl;" to "listen 1.2.3.4:12345 ssl;". Uncomment lines if you don't need e.g. non-SSL and IPv6.
Hi King555,
Would you mind detailing how you got this working? I'm trying to get my server to let me enter the admin panel using a spare IP on port 443 (1.2.3.4:443 or just https://1.2.3.4 for example). I would prefer to leave port 8443 working as well. I have take the steps you have in this thread and can get to my admin panel using https://1.2.3.4 but at one point when it forwards me to the SSO screen it goes to the 1.2.3.4:8443 address which I can't have due to the port being blocked by my ISP. If you could help me out I would really appreciate it.
Thank you,
Mike
