Fresh Installation MySQL Bombed then Recovered with Reboot
danallen1
Basic Pleskian
I need to find out how this happened and how to prevent recurrence.
On a fresh installation on Ubunuto 14.04, installed plesk for free trial. I plan to license it for this server, but am going throgh startup and testing. Been running plesk for a few years, and somewhat familiar with what is going on.
I was setting a new database from the command line, and using phpmyadmin and mysql died. Could not login to panel, got this message:
error: zend_db_adapter_exception: sqlstate[hy000] [2002] no such file or directory (abstract.php:144) -
I found some documentation on this decided to try reboot and that fixed it.
What the heck happened and why? It cannot be normal for this to happen. i was not touching configuration of anything. Is there somewhere I can look to reconstruct what happened?
thank you.
Thats very strange, it happed today after reboot the system, my server runs suse and plesk v12. and thhe error is SQLSTATE[HY000] [2002] No such file or directory (Abstract.php:144).
I did 20 reboots and the message still the same, all my webpages are down, more than 100, all i know is that i didn´t tounched anything and that plesk is set to auto update. So i'm thinking that it could be from some update...
I have found some solutions here http://kb.odin.com/en/120312 but it's not my case
