Maxwell Banks
Hi!
I have a plesk server at centos 7 wiht local ip, because I have a FW with public ip with port forward.
All server work great, except ftp service (proftpd)
If I try access ftp from linux ftp client, the server respond ok, and I can make a dir and recieve all directory, but before to recieve the directory say:
ftp> dir
229 Entering Extended Passive Mode (|||12750|).
150 Opening ASCII mode data connection for file list
Allways from Windows and when at linux put passive command I recieve:
ftp> passive
Passive mode: off; fallback to active mode: off.
ftp> dir
200 EPRT command successful
425 Unable to build data connection: Permission denied
I fix it the problem puting a comment at line
#MasqueradeAddress XX.XX.XX.XX #Public IP
at virtual host section at file
/etc/proftpd.d/50-plesk.conf
... but these file say at header:
#ATTENTION!
#DO NOT MODIFY THIS FILE BECAUSE IT WAS GENERATED AUTOMATICALLY,
#SO ALL YOUR CHANGES WILL BE LOST THE NEXT TIME THE FILE IS GENERATED.
Where is the correcte place to change these configuration?
Thanks a lot!
Maxwell.
ftp> dir
ftp> passive
ftp> dir
#ATTENTION!
Thanks a lot!
Maxwell.
