K
		killswitch999
Please view my installation below. Im having endless issues with this and i cant seem to fix it.
There are 86 packages required for product to function properly, which
were not found in your system.
There are 0 packages that need to be upgraded
in order to install the product.
N) Install packages;
S) Show a list of packages; L) Back to primary components list;
Q) Cancel installing;
Select action [N]:
Installing packages
Reading package lists...
Building dependency tree...
Reading state information...
The following packages were automatically installed and are no longer required:
exim4-config exim4-base
Use 'apt-get autoremove' to remove them.
Suggested packages:
apache2-doc apache httpd libgeo-ipfree-perl libnet-dns-perl libnet-ip-perl
bind9-doc resolvconf defoma-doc dfontmgr psfontmgr x-ttcidfont-conf
exim4-doc-html exim4-doc-info eximon4 libmail-spf-query-perl mail-reader
php-pear uw-mailutils dbishell libfreetype6-dev libgd-tools geoip-bin
libcompress-zlib-perl listadmin lynx spamassassin mysql-doc-5.0 tinyca
ca-certificates openssl-doc oidentd ident-server postgresql-doc-8.3
python-libxml2-dbg sqlite3-doc zip
Recommended packages:
libnet-xwhois-perl libft-perl libbsd-resource-perl xml-core
libhtml-template-perl
The following NEW packages will be installed:
apache2 apache2-mpm-prefork apache2-utils apache2.2-common awstats bind9
defoma drweb-base drweb-daemon drweb-updater exim4-base exim4-config
fontconfig-config gawk libapache2-mod-fcgid libapache2-mod-perl2
libapache2-mod-php5 libapr1 libaprutil1 libboost-date-time1.34.1
libboost-filesystem1.34.1 libc-client2007 libcurl3 libdb4.5
libdbd-mysql-perl libdbi-perl libdevel-symdump-perl libfontconfig1
libfreetype6 libgd2-xpm libgeoip1 libjpeg62 liblockfile1 libmysqlclient15off
libnet-daemon-perl libpam-plesk libpcre3 libperl5.8 libplrpc-perl libpng12-0
libpq5 libspf2-2 libt1-5 libwww-ssl0 libx11-6 libx11-data libxau6
libxcb-xlib0 libxcb1 libxdmcp6 libxml2 libxmlrpc-c3 libxpm4 libxslt1.1
mailman mailx mlock mysql-client-5.0 mysql-common mysql-server-5.0 openssl
openssl-blacklist php5-cgi php5-cli php5-common php5-curl php5-gd php5-imap
php5-mysql php5-xsl plesk-base plesk-skins postgresql postgresql-8.3
postgresql-client-8.3 postgresql-client-common postgresql-common psa psa-api
psa-api-rpc psa-autoinstaller psa-awstats-configurator psa-courier-imap
psa-drweb-configurator psa-hotfix3-9.0.0 psa-hotfix4-9.0.0
psa-locale-base-en-us psa-mail-driver-common psa-mail-qc-driver
psa-mailman-configurator psa-mod-fcgid-configurator psa-php5-configurator
psa-proftpd psa-proftpd-inetd psa-pylibplesk psa-qmail psa-qmail-rblsmtpd
psa-updates pwgen python-libxml2 sharutils sqlite3 ssl-cert sw-cp-server
sw-engine ttf-dejavu ttf-dejavu-core ttf-dejavu-extra unzip webalizer
x11-common xinetd
0 upgraded, 112 newly installed, 0 to remove and 0 not upgraded.
Need to get 1594kB/137MB of archives.
After this operation, 392MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
gawk x11-common libx11-data libxau6 libxdmcp6 libxcb1 libxcb-xlib0 libx11-6
libapr1 libpq5 libaprutil1 apache2-utils apache2.2-common libpcre3
apache2-mpm-prefork apache2 openssl mysql-common libnet-daemon-perl
libplrpc-perl libdbi-perl libmysqlclient15off libdbd-mysql-perl
mysql-client-5.0 mysql-server-5.0 sw-cp-server libboost-date-time1.34.1
libboost-filesystem1.34.1 mlock libc-client2007 libcurl3 libfreetype6
libjpeg62 libpng12-0 libxml2 libwww-ssl0 libxmlrpc-c3 libxslt1.1 sw-engine
plesk-base xinetd psa-courier-imap sqlite3 psa-qmail pwgen mailman libdb4.5
defoma ttf-dejavu-core ttf-dejavu-extra ttf-dejavu fontconfig-config
libfontconfig1 libxpm4 libgd2-xpm libgeoip1 webalizer psa-pylibplesk awstats
bind9 libdevel-symdump-perl libperl5.8 libapache2-mod-perl2 liblockfile1
mailx plesk-skins psa-api psa-locale-base-en-us libspf2-2
psa-mail-driver-common psa-qmail-rblsmtpd psa-mail-qc-driver php5-common
libapache2-mod-php5 php5-cgi php5-cli php5-curl libt1-5 php5-gd php5-imap
php5-mysql php5-xsl psa-php5-configurator psa-proftpd psa-proftpd-inetd
python-libxml2 sharutils unzip psa libpam-plesk openssl-blacklist drweb-base
drweb-updater drweb-daemon libapache2-mod-fcgid postgresql-client-common
postgresql-client-8.3 ssl-cert postgresql-common postgresql-8.3 postgresql
exim4-config exim4-base psa-api-rpc psa-autoinstaller
psa-awstats-configurator psa-drweb-configurator psa-hotfix3-9.0.0
psa-hotfix4-9.0.0 psa-mailman-configurator psa-mod-fcgid-configurator
psa-updates
Authentication warning overridden.
Err http://autoinstall.plesk.com hardy/all psa-courier-imap 3.0.8-ubuntu8.04.build90081222.11
302 Moved Temporarily
Failed to fetch http://autoinstall.plesk.com/ubuntu...ap_3.0.8-ubuntu8.04.build90081222.11_i386.deb 302 Moved Temporarily
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Hit http://za.archive.ubuntu.com hardy Release.gpg
Hit http://za.archive.ubuntu.com hardy-updates Release.gpg
Hit http://za.archive.ubuntu.com hardy/main Packages
Hit http://za.archive.ubuntu.com hardy/restricted Packages
Hit http://za.archive.ubuntu.com hardy/main Sources
Hit http://za.archive.ubuntu.com hardy/restricted Sources
Hit http://za.archive.ubuntu.com hardy/universe Packages
Hit http://za.archive.ubuntu.com hardy/universe Sources
Hit http://za.archive.ubuntu.com hardy/multiverse Packages
Hit http://za.archive.ubuntu.com hardy/multiverse Sources
Hit http://za.archive.ubuntu.com hardy-updates/main Packages
Hit http://za.archive.ubuntu.com hardy-updates/restricted Packages
Hit http://za.archive.ubuntu.com hardy-updates/main Sources
Hit http://za.archive.ubuntu.com hardy-updates/restricted Sources
Hit http://za.archive.ubuntu.com hardy-updates/universe Packages
Hit http://za.archive.ubuntu.com hardy-updates/universe Sources
Hit http://za.archive.ubuntu.com hardy-updates/multiverse Packages
Hit http://za.archive.ubuntu.com hardy-updates/multiverse Sources
ERROR: An error occurred on attempt to install packages.
Attention! Your software might be inoperable.
Please, contact product technical support.
Thanks in advance for the help.
Select action [N]:
Installing packages
Suggested packages:
x11-common xinetd
psa-updates
