Resolved Login to Plesk from Power panel
ITTECH
Basic Pleskian
Dears,
Hope you are doing well!
Kindly note that I have this issue after upgrading to plesk 17.0.17
When trying to open Plesk from Virtuozzo Power panel i get the following:
An internal error occurred in Plesk.
Due to security reasons the option \'-show-password\' is no longer supported. Use \'--get-login-link\' to generate a one-time login link
Either Windows or Linux, it is the same.
Please advise,
Best regards,
Hi ITTECH,
actually, your notice is not an issue/error/bug, but a security enhancement at Plesk Onyx. It is not possible anymore to use the "-show-password" option, to get the clear-text password ( not encrypted ). Pls. inform yourself about existent options at:
If your Virtuozzo Power Panel ( which is not from Plesk! ) hasn't been updated/upgraded yet, pls. get in contact with your provider, to solve your issue. Here at the "Plesk Community Forum", we try to support "Plesk related issue(s)/errors/problems/discussions", while the Virtuozzo Power Panel is supported at => Support - Virtuozzo
