Question Maintenance-Mode CLI
omexlu
Regular Pleskian
Hello,
What is the syntax to enable and disable the maintenance mode over SSH for a website?
And is it maybe necessary to 'sleep X' few seconds in a bash-script after the command?
Thanks in advance.
History of Changes
Code:
Websites maintenance mode
(*) subscription, site, subdomain utilities:
Deprecated option: -maintenance-mode. The Suspended website status is used instead (see the next change).
The Suspended status of websites
New command: --suspend.
Hello @IgorG
Thank you, what would be that command? Maybe to suspend multiple domains at once?
And a sleep X is needed maybe?
Thanks.
Just use something like
# for i in `mysql -uadmin -p\`cat /etc/psa/.psa.shadow\` psa -Ns -e "select name from domains"`; do /usr/local/psa/bin/site --suspend $i; done
@IgorG
Hello,
This thread might be old but is it possible to disable more than 1 domain in one line like:
/usr/local/psa/bin/site --suspend domain1.tld domain2.tld
In this example maybe it is possible to avoid multiple services restarts?
Thanks.
Try something like:
statement "select name from domains" you can replace according to your needed conditions.
Try something like:
Thank you, but what if I don't want to take all domains from database and only need few specific domains?
OK I will give it a try, but is there not another possiblity without sql statement?
For a single domain it works without.
Thank you very much for always your help :)
what about create a textfile with the specified domain names you want one per line and write a script which read the textfile and do the requiered action/command per domain? There are a lot of examples around just google for it
