Plesk ftp problem
CahitE
Basic Pleskian
I am using centos 5.4 with plesk 10.0.1 and when i try to connect to ftp i got the following error :
421 Service not available, remote server has closed connection
i have tryed to ping and resolve domain domain both of them has been succed and i 've checked what if a program listen 21 port :
lsof -i tcp:21
but it seems ok as described here http://help.godaddy.com/topic/93/article/1587
what should be the problem
I also try to connect locally but the result is same as given above
is this packge installed automatically during upgrade ( 9.3 => 10.0.0 => 10.0.1 ) ?
how can I check it ?
thanks
Check it with usual rpm utility with something like
# rpm -qi psa-proftpd
