Problem... again
Peter-
Basic Pleskian
Hello, Parallels
I'm getting an error with update 47 (while trying to update):
Execution failed.
Command: autoinstaller
Arguments: Array
[0] => --select-product-id
[1] => plesk
[2] => --select-release-current
[3] => --upgrade-installed-components
ERROR: Failed to run the Yum utility.
The Yum utility failed to install the required packages.
Attention! Your software might be inoperable.
Please, contact product technical support.
Need more related error messages from autoinstaller log.
Found something more:
warning: rpmts_HdrFromFdno: Header V3 RSA/SHA1 Signature, key ID 4520xfa9: NOKEY
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY.art.txt
Fatal error during packages installation: The GPG keys listed for the "CentOS / Red Hat Enterprise Linux 6 - atomicrocketturtle.com" repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository.
YumBaseError: The GPG keys listed for the "CentOS / Red Hat Enterprise Linux 6 - atomicrocketturtle.com" repository are already installed but they are not correct for this package.
Yeah, worked after yum upgrade atomic-release. Thanks.
I see 12 is out? How do I upgrade? Or am I allowed to do that with my current plan?
