Problem During Ftp Backup
jaberz
Hello
i have 6 plesk server in my company
i start ftp backup on all of this server
but one of my server do not transfer created backup to FTP server
when i test ftp setting it is correct,
and when i start only Server configuration backup it is successfully transfer to ftp server
but when i select Server configuration and content backup is created but do not transfer to ftp server
without any error
Please help me to solve this problem
Thank you
Plesk don't Generate any log
after change some setting
backup tart transfer to ftp server but not completely
plesk log says :
Failed to pack files backup_info_1404131410.xml in /usr/local/psa/PMM/tmp/backupdDAgDW [ 1039747072 bytes free of 9288978432 bytes total on mount point 0]
after that i change
DUMP_TMP_D
to another directory
but problem not solved
