T
TorstenS
Hello,
my old Plesk installation with 7.5.4 "is gone", but I have a full backup
Now I reinstalled my root server with Plesk 9.2.3 and tried to migrate my backup.
Here is what i have tried:
1) copy the backup to new installation
2) Plesk (clean install) -> Migration Manager -> choose local file, pointed to the backup file and started
3) after waiting about one hour (my backup is 74GB) the "Please Wait" screen disappears and forwards me to the main plesk desktop, but there are no resellers, clients but the disk usage has grown up about 74GB...
After some research on my server, I found some logfiles, but the errors aren't very useful.
First log I found is the pmmcli.log at /usr/local/psa/PMM/logs.
Another log is called migration.log and resides in the same folder as my original backup file.
After many searches at google and the forums, I didn't find a solution or even an explanation whats wrong...
Are there other logs I missed? Is there a chance to import the "converted" backup? Or went something wrong with the conversion? Any chances to "rescue" the whole thing?
Every hint would be very nice
Greetings Torsten
BTW: the KB5864 at http://kb.odin.com/en/5864 did not mention, that the backup from 7.5 cannot directly converted with pre9-converter, but other sources do so. Weird, issn't it? (I tried and it didn't do the trick)
Code:
4887: 2009-11-08 14:58:25,559 INFO Create restore session 20091108145825999 started
4887: 2009-11-08 15:44:31,702 INFO Initialized restore session 20091108145825999
4887: 2009-11-08 15:44:34,709 CRITICAL Runtime error in pmmcli:
<class 'xml.sax._exceptions.SAXParseException'> /usr/local/psa/PMM/rsessions/20091108145825999/info.xml:1:0: syntax error
Traceback (most recent call last):
File "/usr/local/psa/admin/share/pmmcli/pmmcli.py", line 1846, in main
data_action_response, errcode_response, error_message = actions.get(sys.argv[1][2:])(parameters)
File "/usr/local/psa/admin/share/pmmcli/pmmcli.py", line 1691, in restore
return ActionRunner(RestoreAction, restore_task_specification, parameters).doActivity()
File "/usr/local/psa/admin/share/pmmcli/pmmcli.py", line 75, in doActivity
result = self.processor.doActivity()
File "/usr/local/psa/admin/share/pmmcli/pmmcli.py", line 491, in doActivity
session = pmmcli_session.PmmcliSession.createSession(owner_type,owner_guid,dump_specification_formatter.get_destination_file(),dump_specification_formatter.buildString())
File "/usr/local/psa/admin/share/pmmcli/pmmcli_session.py", line 208, in createSession
pmm_dump_overview.DumpOverviewCreator(session.get_session_id()).create(session.get_info_xml(),session.get_dump_overview())
File "/usr/local/psa/admin/share/pmmcli/pmm_dump_overview.py", line 353, in create
xml_processor.process()
File "/usr/local/psa/admin/share/pmmcli/pmm_dump_overview.py", line 74, in process
parser.parse(open(self.__info_xml))
File "/usr/lib/python2.6/xml/sax/expatreader.py", line 107, in parse
xmlreader.IncrementalParser.parse(self, source)
File "/usr/lib/python2.6/xml/sax/xmlreader.py", line 123, in parse
self.feed(buffer)
File "/usr/lib/python2.6/xml/sax/expatreader.py", line 211, in feed
self._err_handler.fatalError(exc)
File "/usr/lib/python2.6/xml/sax/handler.py", line 38, in fatalError
raise exception
SAXParseException: /usr/local/psa/PMM/rsessions/20091108145825999/info.xml:1:0: syntax error
4887: 2009-11-08 15:44:37,916 INFO Outgoing packet:
<?xml version="1.0" encoding="UTF-8"?>
<response>
<errcode>1001</errcode>
<errmsg>Runtime error in pmmcli:
self.feed(buffer)
raise exception
</errmsg>
</response>
Code:
[16:11:06|INFO: 6934:p.log] pmm-ras started : /usr/local/psa/admin/bin/pmm-ras --get-dump-info --dump-file-specification=/usr/local/psa/PMM/rsessions/20091108133042280/info.xml
[16:11:06|INFO: 6934:p.log] Repository '/var/lib/psa/dumps' initialising...
[16:11:06|INFO: 6934:p.log] Repository '/var/lib/psa/dumps': Initialized
[16:11:06|INFO: 6934:p.log] Repository '/var/lib/psa/dumps': Get backup info from /usr/local/psa/PMM/rsessions/20091108133042280/info.xml
[16:11:06|INFO: 6934:p.log] Repository '/var/lib/psa/dumps': Get initial backup info from dir /usr/local/psa/PMM/rsessions/20091108133042280/.discovered/info
[16:11:06|INFO: 6934:p.log] Get backup params from listing of /usr/local/psa/PMM/rsessions/20091108133042280/.discovered/info
[16:11:06|INFO: 6934:p.log] pmm-ras finished. Exit code: 151
Greetings Torsten
