Yuttana Hiruntraporn
Hi, I have installation on plesk in the following
Main components list for Plesk Control Panel
23 of 44 components selected
Please select the components of Plesk Control Panel you want to install:
1. * Base packages of Plesk
2. [*] Plesk Updater
3. [*] PHP5 support
4. [*] PostgreSQL server support
5. [*] Application vault packages
6. [*] Plesk Professional Web Site Editor
7. [*] Plesk API [former Plesk Agent]
8. [*] Plesk migration manager
9. [ ] SiteBuilder publishing support for Plesk
10. [ ] SiteBuilder module migration suite
11. [ ] ColdFusion support for Plesk
12. [ ] MIVA Empresa support
13. [ ] Plesk billing
14. [.] <+> Plesk hosting features // 4 of 5 components selected
Different mailservers
15. ( ) Qmail mailserver
16. (*) Postfix mailserver
17. [.] <+> Additional Plesk modules // 4 of 5 components selected
18. [ ] <+> Game servers // 0 of 3 components selected
19. [.] <+> Addition mail services // 3 of 4 components selected
20. [.] <+> Server backup solutions // 1 of 2 components selected
21. [ ] <+> Additional language packs // 0 of 9 components selected
22. [*] <+> Plesk webmails support // 2 of 2 components selected
N) Next page; P) Go back; Q) Cancel installing;
A) Select all; D) Deselect all;
Enter number to toggle the component or to overview the group;
Type a number or a character of desired action [N]:
Retrieving information about the installed packages...
Downloading the file PSA_9.0.1/update-rpm-RedHat-el5-i386/update-9.0.1-rhel5-i38
6.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% done.
Downloading the file PSA_9.0.1/dist-rpm-RedHat-el5-i386/build-9.0.1-rhel5-i386.h
Downloading the file PSA_9.0.1/thirdparty-rpm-RedHat-el5-i386/thirdparty-9.0.1-r
hel5-i386.hdr.gz: 10%..25%..31%..40%..52%..64%..70%..82%..90%..100% done.
Determining the packages that need to be installed.
ERROR: Unable to install the "psa-9.0.1-rhel5.build90090127.18.i586 (b 0x96fc760
source=0x8b49b10 P:3636 R:85)" package.
The following could cause the installation failure:
Packages "bind-libs-30:9.3.4-6.P1.el5.i386 (u 0x8e94748 source=0x8b49958 P:22 R:19)"
and "bind-libs-30:9.3.4-10.P1.el5.i386 (s 0x8ae9358 source=0x8aa3f38 P:22 R:19)"
cannot be installed at the same time
because of the conflict on the file "/usr/lib/libbind.so.4"
Not all packages were installed.
Please, contact product technical support.
What is this problem???
installation file is
parallels_installer_v3.4.1_build090120.13_os_RedHat_el5_i386
and
OS is Red Hat Enterprise Linux Server release 5.3 (Tikanga)
3. [*] PHP5 support
and
