    https://survey.webpros.com/
  • On Plesk for Linux mod_status is disabled on upgrades to improve Apache security.
    This is a one-time operation that occurs during an upgrade. You can manually enable mod_status later if needed.
Problem With Application
S
Sier
When I try to install the application phpBB
I get this error message:
SiteAppPackagemanager::installSiteAppExtract() failed:
cSiteAppManager::sappmng_extract_application() failed: Incorrect function. (Error Code 1) at extractArchive(C:\Program Files\SWsoft\Plesk\var\cgitory\phpBB-2.0.15-4/apps/httpdocs-files.tar, c:\inetpub\vhosts\seemund.com\httpdocs\forum
Running Win 2003 Server. :D
Where can I get packages for applications? How can I make .tar in windows... What if I want to add a language to the phpBB i should add it in httpdocs-files.tar\language, correct? But I dont know how to edit the .tar file, Can't i Just change something so it accepts .zip? Thanks
If not, where can I get the standard phpBB package(that comes in plesk)?
Please try: Windows - Add/Remove programs - Plesk - Modify - Plesk Site App - phpBB
phpBB package located in phpBB.msi file
