Problem with Atmail
sao sang mo
I can not send any email in Atmail. I check the error_log and get many lines as below:
Code:
[Mon Apr 29 01:49:28 2013] [error] [client 222.252.102.69] PHP Warning:  file_exists(): open_basedir restriction in effect. File(/etc/psa/webmail/atmail/.atmail.shadow) is not within the allowed path(s): (/var/www/atmail/:/var/log/atmail/:/etc/psa-webmail/atmail/:/tmp/:/var/tmp/) in /var/www/atmail/libs/Atmail/Config.php on line 4, referer: http://webmail.removed/parse.php?file=html/LANG/simple/showmail_interface.html&ajax=1&func=Inbox&To=
Please help me.
thanks
Try to reconfigure Atmail with reinstallation. You can find details in
# /usr/local/psa/admin/sbin/webmailmng --help
Thank IgorG for your support,
I have run 2 command lines:
/usr/local/psa/admin/sbin/webmailmng --remove --name=atmail
/usr/local/psa/admin/sbin/webmailmng --install --name=atmail
Then, I test again, the error_log of Atmail displays this message:
[Mon Apr 29 11:53:05 2013] [error] [client 222.252.102.69] File does not exist: /var/www/atmail/javascript/fckeditor/editor/javascript, referer: http://webmail.removed/javascript/f...ml?InstanceName=ComposeMsgText&Toolbar=Atmail
How I can do?
You can try to remove atmail packages with OS package manager and the install Atmail back with Plesk autoinstaller.
