Problem with Backup Process
PedroV.
Basic Pleskian
Hello,
Since some days ago I have problem making backups on Parallels Plesk Panel 11.5 give me this error:
Warning: hosting "domain.com"
Failed to pack files backup-extra_domain.com_logs_1310291039 in /var/lib/psa/dumps/domains/domain.com [ 43033755648 bytes free of 48871917568 bytes total on mount point 0]
Unable to create dump: Unable to create output file '/var/lib/psa/dumps/domains/domain.com/backup-extra_domain.com_logs_1310291039.tgz': No space left on device at /usr/local/psa/PMM/agents/shared/Storage/Splitter.pm line 74.
Storage::Splitter::_writeToPart('Storage::Splitter=HASH(0x23305a0)', '\x{1f}\x{8b}\x{8}\x{0}c\x{90}oR\x{0}\x{3}', 10) called at /usr/local/psa/PMM/agents/shared/Storage/Splitter.pm line 116
Storage::Splitter::addData('Storage::Splitter=HASH(0x23305a0)', '\x{1f}\x{8b}\x{8}\x{0}c\x{90}oR\x{0}\x{3}', 10) called at /usr/local/psa/PMM/agents/shared/Storage/Splitter.pm line 30
Storage::Splitter::run() called at /usr/local/psa/PMM/agents/shared/IPC/Run.pm line 2645
IPC::Run::_do_kid_and_exit('IPC::Run=HASH(0x232e8e8)', 'HASH(0x1e9e3a0)') called at /usr/local/psa/PMM/agents/shared/IPC/Run.pm line 1363
IPC::Run::_spawn('IPC::Run=HASH(0x232e8e8)', 'HASH(0x1e9e3a0)') called at /usr/local/psa/PMM/agents/shared/IPC/Run.pm line 2779
eval {...} called at /usr/local/psa/PMM/agents/shared/IPC/Run.pm line 2776
IPC::Run::start('IPC::Run=HASH(0x232e8e8)') called at /usr/local/psa/PMM/agents/shared/IPC/Run.pm line 1433
IPC::Run::run('IPC::Run=HASH(0x232e8e8)') called at /usr/local/psa/PMM/agents/shared/Storage/Storage.pm line 322
And continues the big log...
I check in Server Information and the info about hard drive is:
Hard Disk Usage
File system Total Used Available Capacity
/dev/root 19 841.20 MB 7 869.62 MB 10 971.63 MB 39.66%
/dev/md2 93 215.79 MB 11 139.48 MB 77 378.46 MB 11.95%
I have a lot of available space. Can anyone help me?
My server is CentOS 6.4.
Thank you
Can you please provide me following command output so that I can try to assist you in this regard.
Code:
df -h
df -i
Please make a note that when ever a backup task is initiated, firstly Parallels Plesk Panel creates a temporary files in /usr/local/psa/PMM/tmp/ and copies backup file from this directory to ftp. Therefore make sure that available free diskspace on '/usr' partitions is really enough.
Hello,
The problem is resolved, it's a problem with disk full of Inodes, I use the command df -i and I found the folder of php sessions are with million files I delete all the folder/files in this path /var/lib/php with name "sessions" and the Inodes return to 8%.
And maintain now in 8% since 29 october. Is possible to check if the cleaner of Plesk is running with success?
Just check that cron task /etc/cron.hourly/plesk-php-cleanuper works correctly.
