Problem with mobile api after migration 10.4.4>11.5.30
Paul Tog
Hello,
yesterday i completed a full migration of my server from version 10.4.4 to 11.5.30 using Migration Manager.
The old server had the mobile api connector installed and working just fine. I had my Android phone connected and monitored the stats.
Now on the new server, although the referring page shows correctly, the folder /usr/local/psa/var/modules/plesk-mobile doesn't exist. Thus, the mobile application cannot connect to the new server.
If i run
Code:
/usr/local/psa/bin/extension --uninstall plesk-mobile
i get the response Module plesk-mobile is not installed.
If u run
Code:
/usr/local/psa/bin/extension --install plesk-mobile
i get the response Unable to open source file. File not exists.
What can i do to resolve this? i really need to keep an eye on the cpu & ram as it is a new machine and problems may arise.
Thank you in advance
Regards
Paul
